I washed mine last weekend - first time in a while - and it looks great.
More importantly, ComandOnline tell me that a firmware update will allow me to increase the Aux output level to the same as as that for the CD player or music register. Basically, turning it up to 11.
Looking for some time to get down there asap.
Changed air filter, pollen filter and cabin filter. What a PITA is the pollen filter to do. Lifted the plastic trim up, swapped filters then could get the bloody thing down!!!
Hopefully do oil, oil filter, spark plugs and front brake pads when I get a chance. 2015 c200 on 109k, has anyone had any coil packs break on them as you remove them?
Washed for the E400 before going to a family funeral in deepest darkest Wales tomorrow.
It does look good clean.
Wife thinks I'm mad as it will get dirty doing nigh on 8 hours of travel, but it had 2 weeks of dust all over it and I like a clean car!
Also, had the SLK into the main dealer for the warranty work.
Passenger wing mirror replaced under warranty as heating element had failed, but as they only found that, they then wanted to still charge me the £189 diag fee!!!
A robust conversation later, they understood that the warranty covers that if a claim is merited (and it was)
So they still get paid - Muppet!
They didn't find the seat belt issue Terry at Wayne Gates did (have dropped him a line) but the issue with the Aircon Terry did find was a regas. Of course it's the 'new' gas so that was £182! (validated with MBS as yep, that's what it is)
I also got a whole health check on it and all green (cue disappointment on the service managers face...) apart from my tyre inflation kit having expired.
But that was another eye cast over the car to reassure me again, which was nice
I can enjoy it now with nothing else on my mind.
The seller (navi..expert) has 927 feedbacks 99.2% positives. The update was on an SD card and I needed to provide my cars VIN number to get the license code. It took just over an hour to install (used ctek then engine on for final 15mins). All seems good. That's all I know.
I got mine for the e350 from this seller £79 , back in 2023 . I deliberately went out of my way to drive on roads that had changed since 2017 when the car was made . The maps did show the changes . The pin number itself from other places was £99 at the time.
Correction there’s always two, I was struggling with the wheels on, he had the wheels off, how long would it have took to scrape the adhesives pads off .
Okay , stay up there on your pedestal 😵‍💫
Did you ask him to ?
Today I drove to a lovely wedding in west wales…
…upon trying to leave at midnight, the brake pedal went all the way to the floor and all brake pressures gone. No brake fluid in the reservoir. Car’s parked in a field.
Having to stay at the rented house with the bride and groom’s family for the next few hours, trying to get a tow back to Cardiff (~2.5h hours away) in the morning. Then I need to get it to a garage that can do the brake pipes in the week.
Overall a fun, cheap, relaxing weekend
Sorry to read that. I hope it’s all sorted with the minimum of hassle.
Thank you - the fun is ongoing! Waiting for the recovery truck… hoping not to get a grumpy recovery person / the minimum of damage to the car. Not had good luck with getting a car on a recovery truck without some cosmetic damage…
,,,upon trying to leave at midnight, the brake pedal went all the way to the floor and all brake pressures gone. No brake fluid in the reservoir. Car’s parked in a field.
To have no fluid at all, and for both sides of the system to be without pressure, sounds astonishing.
At least it was apparent when you were setting off, not when you were part way home.
Be very interesting to learn what caused this, good luck with the conscientious recovery driver Teddy'.
I’ve had the same exact thing/feeling happen in my E39, as well as a big ‘check brake fluid level’ warning in red, so I knew exactly what the issue was. There’s so much pressure when you press the brake it doesn’t take much of a hole to lose it. I don’t think it’s unusual.
I also had a minor advisory on a very recent MOT, but I didn’t think it would last so little time. Should have dealt with it immediately, of course, so it’s my fault.
Not today but yesterday.
Oil and oil filter change. Belly panels were awkward to remove!!!
Panoramic sunroof service (well a decent attempt at it) using a guide someone has put up on another post and YouTube. Used the MB stuff from eBay, £14 for lip balm size pot of the grease and 10ml of the lubricant.
The very next day after this happened I got into my other W212 E-Class to give my friend a lift to the station. This W212 has had an easy life and been babied, very low milage. It had been sat for a week or two.
As soon as I hit a bump on the drive I heard a rattle noise from the front - almost as if I'd left a spanner or socket in the engine bay, rattling around. This continued for a while, every now and again I'd get out and expect to see something hanging off the car, I even tightened the wheel nuts just to be sure, checking the engine bay multiple times...
After a couple of miles, I heard a big clunk and whatever was rattling around fell and hit the bottom of the car, onto the road. I pulled over to go check out what it was... see pic.
Apparently this car decided to lose part of its front spring - I have no idea how as it didn't hit a pothole and has just been sat for a while without use, and there were no rattles or bumps.
In fact what's weird is that the car drives perfectly, you would never know. No knocks or noises, no strange driving dynamics. To the point I even questioned if it was a spring of someone else's car that I found on the road, and it actually was a spanner.
So, a very expensive two days. It's almost defeating me - as in, I'm almost read to sell them both and get whatever the most reliable, boring econo-car is.
Hope that was a legit deal....the car that towed it away was stolen off a drive in Suffolk a few months back!!!
Jeez, made my **** go like a rabbits nose then.
Booked from Shiply, 99.1% positive reviews and not the cheapest.
The news story is from May 2023, last change of V5 was September 2023, so looks like the transport guy has bought a stolen recovered vehicle.
Blimey, how did you notice that?
My naturally suspicious and untrusting nature that you get after 37 years of buying/selling for a living!!! 😄 👍
