where to buy Foot rest plate C-class 2012 s204
It was a while ago, no active links, I'm afraid.
As I said - it's a standard floor-mounted pedal cover.
I think so ;):
This is the accelerator pedal cover from the E-class, trimmed and fitted with a velcro back.
Here's a better view:
And a close-up:
I like the blue porno light you have illuminated under your dash. :)
so you put the foot rest plate ontop of your mat?
how do you remove mat and foot plate when you clean your car?
is it strong velcro?
if you happen by mistake kick the foot plate with your shoe, das foot plate wobble and come off from carpet?
I also have blue lights in door handles and pull recesses, power socket tray and central drink holder ... although I'm a bit concerned with your lighting colour association o_O
This mat set has the lip, so yes, the footrest goes on top of it, the other set is the same shape as AMG, so no lip, and the footrest then goes direct onto the carpet.
Simple to remove in either case, as it's not glued/screwed/nailed or molecularly fused to the mat/carpet.
The velcro is a genuine VELCRO industrial strength low profile 91050 tape - no wobble, doesn't move, and certainly never comes off by itself.
It's much finer and shorter, than the usual generic velcro. I normally use 3M Dual Lock in the car, but it obviously requires both sides to be dual-lock, for it to work.
I ment it's a cozy ambient light, gives a little bit of a niteclub asociation
  • Like
Reactions: GLK
Yeah right..
At weekends you neck some pillages , crank up the Command and get out the glow sticks :D
How are these attached, under the carpet? My C63 doesn’t have one, I can’t remember if my C200 did but I know my left foot feels more uncomfortable in the new car
You mean the footrest?
It's just a strong velcro, stuck either to a mat, or directly to the carpet.
There are types, which held in place with screws, but I don't like that.
Oh I think I’d need a fixed one, that would make me paranoid about it coming loose and ending up below the brake pedal. Happened in my work van a bottle rolled across the floor from the passenger side and got stuck, brief moment for change of underwear was needed!
  • Like
Reactions: GLK
