Well I'm assuming it's a write off. Doesn't look quite so bad here as the bonnet vertical bits around the grille were pushed back behind the headlights until I liberated them to pump out some of the full tank of petrol. With the bonnet push that far back I was suprised it was still driveable.
Needs:
Bonnet, Slam Panel, Headlamps, Air-con Condensor (possibly fans), Grille, numerous pipes, clips, shrouds etc. The nose dive at the front means the bumper is just badly scratched, but could be salvaged. Radiator holds water, but is pushed back right against the fan. Brake pipes pushed against the ABS unit but looks OK.
What do folks reckon, write off? With 153K on the clock value must be between £1500 and £2k. Doesn't by a lot of parts/labour/paint.
I'm a slightly uncertain because the front wings are untouched and the beam behind the bumper looks straight - that they might attempt a repair. Anyone more knowledgable care to comment?
Needs:
