Charging at a Premier Inn....heh heh....
Nice parking space! It looks like an 8m cable might almost have been enough without the extension lead...
Lots of rolled eyes from your travelling companion?
Hi Dave, I do 90% of my charging with Source London as there is a point under 5 minutes walk from my house.
Positives:
1. Price
2. The app is really good and accurately tells you when chargers are free.
3. They appear to still be building out the network, so are adding points regularly (perhaps not fast enough, but given the price they charge can't complain)
4. Good service. I've had to ring their helpline a couple of times (lost card/not working point) and got answered really quickly.
Negatives:
1. They are taking over the networks previously run by councils and in my experience a number of charging points simply don't work (but of course show up on the app as being free). I use the Source London app in conjunction with 'Plug share' which can be better at alerting you to points that are listed but not working.
Hope that helps.
I've been in touch with MB "Customer Service" about winter tyre sizes for the C350e. As you probably know, certain options on the estate model force you to have 18" wheels, and I was interested to know if I had to stick with this size for winter. There is no information in the manual or on the car.
Their reply in italic:
I can confirm that the best winter tyre for your Mercedes-Benz vehicle is the Pirelli - Sottozero 3 (95) load rating (H) Speed rating (Non Run-flat), this tyre is the same size as the tyres that are currently fitted on your Mercedes-Benz vehicle. (i.e. 225/45/18 front and 245/40/18 rear.)
My Technical Department also advised 17 inch winter tyres for your vehicle:
Front - 7J X 17 H2 ET48.5 (225/50/17 tires)
Rear - 8J X 17 H2 ET54 (245/45/17 tires)
So it would seem we can drop to 17" rims for winter which helps a bit with costs. They clearly don't want to drop from a non-staggered setup though which is a shame. Must be all that battery weight they are worried about!
I thought the 18" were mandatory because of extra weight on the premium packs, but then they let you drop to 17" winter tyres.....bit strange.....
Has anyone had a problem with the alarm sounding unexpectedly. Happened twice last night. On the second time I went out and opened my boot and closed it the reason being it's just been repaired and may have no relevance but thought I should mention it.
Dunno about that but my consumption has gone to litres which is of course meaningless!Anyone else found that since the Mercedes Me Connect web app update the mpg is stuck and not corresponding to what the car is doing?
Thanks for that tip, found it in settings on the Mercedes Me App, Ta!Mine switched to litres, but I've switched it back now. It seems to be correct from start and from reset.
No issues here - I had to change from litres to mpg which was easy enough but my Mercedes Me web app showed 99.9 for the weekend use as I was driving wholly on electric..I think there is a bug where it only ever shows 80MPG maximum in the app now, so because my "since start" is 99.9MPG and my "since reset" is currently 94.1MPG, it only shows 80MPG.....hopefully they will fix.
