ASnowman
- Dec 7, 2015
- Merchedes C 350E
Ready for autobahn.
Is there anybody out there?
like spa for the ladies ;-) this was outside the hotel.
Command on line really good, Really enjoying the sound quality of Burmester system. Worth the wait!
Bit cheesy.... Got a 64gb usb stick in the shape of the mercedes key fob from eBay for £16.. Not that you see it under the arm rest!Getting both, and filled a SD card with Pink floyd the wall in 320kbs mp3 for testing tomorow.
Trip for life. What a car 900 km autobahn done. Factory tour amasing!!! Have lots off pictures. Broke the drive in speed a "tad" a couple of times. I can tell you. Its fast.
But you know it's there......Bit cheesy.... Got a 64gb usb stick in the shape of the mercedes key fob from eBay for £16.. Not that you see it under the arm rest!
Had my cavansite blue, premium plus saloon on 17 inch winter tyres for just over a month and driven just under 3000 miles. One long run to France from the UK. Brilliant car, great to drive, averaged about 43 mpg. Command on line really good, I have downloaded over 4000 iTunes tracks onto a usb stick that also shows all the album covers. Really enjoying the sound quality of Burmester system. Worth the wait!
thats quite good going MPG wise for such high mileage, I'll be doing around a third of your mileage per month, and if i can get what your getting i'll be more than happy.
If you stick to motorway speed limits and charge daily you should see that mpg without too much of a problem, in my limited experience of just 250 miles. Am currently running at 56mpg in that time but ran on electric for local journeys over the whole weekend, which skews the total somewhat.
Sent from my SM-G900F using Tapatalk
Problems charging.
Company had a Rolec socket fitted in the car park yesterday so I'm trying the charging using the mode 3 cable for the first time but having problems.
I've got the car hooked up using the mode 3 cable and the socket led goes solid blue, indicating it's ready to charge, the socket locks to the car, but I can't get the charging to start. It's not set for timed charging and previously using the mode 2 cable charging starts straight away.
The charge rate is set to maximum in the menu too, also it's not that.
Any ideas what I'm doing wrong??
I have been told that sometimes with the heavy cables it looks like they are plugged in, but they are not.
I had an issue at Ikea where I couldn't unplug the car because the cable was stuck. A friend of mine had a problem with the i3 where he plugged it in, but it wouldn't take the charge.
have a bit of a wiggle and see if that helps.
