Changing ML270 Pollen Filter
J30BOS
ML270 CDi
Hi
How do I change the pollen filter on my ML270 2000 plate - I don't even know where it is!!!!:confused:
Any help would be appreciated.
From memory,you have to remove the panel below the glove box, it there somewhere.
Thats right. After removal of the panal under the dash, you will find a rectangle cover with clips on it, just slide the clips and it should take the cover off the box and pull out the pollen filter.
Changed one today on a 2004 plate , 45,000 miler that I just bought. Absolutely black and filled with the remains of dry leaf and other debris. Hope to see a difference in the flow of air in the car now.
