1st off, all the best hope all had a good Christmas...and as this will most likely not get read until 2020 Happy New year LOL !!!!
OK update....its not that great to be honest. Took ML into a local Diesel specialist that I had planed on doing a pro remap anyway with it being a ML280 and knowing its exact same engine as the ML320 I always planned to just get it pro remapped.
So dropped it off with them having told about the issue and thay basically said knowt wrong with it! They did the remap and yes there is a noticable differance in power but untill today even though I have been using it I had not let it idle for the time needed to see if issue still there.
It was quite nice today so decided to fit some "glasses" holders (one for your face) (sick of having to leave them in a the cup holder) and give it a clean.....left the engine on for a good 30 mins and the issue is defo still there!!!
Kinda wish I hadn't coz its bugging me knowing somthing is wrong.....its got the new PCV valve and I have fitted a catch tank....tho I have just ordered another with a beather on as current one does not. Ordered the new improved ORANGE inlet seals which broke the inlet "T" tube end....so had to buy the Silcone one....you basically cut the end off and the whole end is silicone pipe including the PVC pipe inlet...so mine looks like this now....(but this is not my car)
So, there is defo a little play in the turbo shaft.......so plan on changing the turbo! Theres a place around the corner from me that recon them using all EU parts....will cost £400 then get £150 back when I drop off my turbo....so did not thing that was a bad price...inc all fitting kit too.....and they will give me 2-4 weeks to get the job done.
Who thinks this is the cause?
I've read the valve stem seals going can give my issue....but every thread I read on it also says you'll get blue smoke on 1st start up and I dont get any at all.....so my thoughts and hopes are that rules out stem seals...
Piston rings I just dont think so......just dont see it could cause issue only at idle.....and on a turbo I'd expect loads on boost if it were piston rings......??????
As its getting darker earlier and having owned much older diesels I know that at night time with car behind you with lights on is the best time to see smoke from your own car...and though I cant say none at all.....to me its what I would class as normal to none....again remember we now know its a none DPF car.
Oh just remembered.....on the PCV system on some videos I watched on other cars too....theres two pipes, is that just for petrol engines i.e. pcv going to intake after throttle body and one before going to just after air box?
Only ask because so many other threads I've read up on that do have the exact issue I had it ends up being posative crank ventilation....hence new catch tank on order with little filter on top! Just wondering if there could be another pipe blocked.....
Is the valve in it shut at idle and open on throttle or other way around? Just thinking at idle if shut and if there is more crank pressure than there should be that could be it but thought all crank pressure would just go back into intake....
Arrgggg my head starting to hurt with it all .....I love the car tho so much now I had it a few months...fantastic drive quiet, its like new.....just need this sorted for peace of mind......
Sorry its a long post.......
