Hi Folks,
A friend of mine is having probs with his W202 C280 (V6).
It broke down last night with the following symptoms:
When trying to start the car, it will intermittently start and not rev above 1000rpm. It would then cut out and not spin the starter motor...on turning the key to start position there is nothing....ignition is fine and the battery is fine. The radio now has no power to it as well.
It certainly doesn't sound like a CPS problem and sounds like a relay issue.
Can anyone point me in the direction of the fuel pump and ignition relays ?
Are they one unit or separate and where can they be found and how do you identify it ?
Many Thanks
Many Thanks
