- Feb 8, 2007
- Location
- Portsmouth, Hampshire.
- E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
The build date is the important one.
Hi thanks for the very kind offer but,I think I may have the bulletin. I will do dome digging.
JOHN. Send me your chassis number via PM and I will tell you your build date.
The official order date for our vehicle was the 23rd September 2003, the build date was January 2004, and the delivery was the first week of February 2004. It just fitted into the official date for nano paintwork.
John
Edit
Totally agree about the build date. That is the real nitty gritty question
John, is there any way that you could get someone to look at the top of the oil cooler by the side of the rad to see if there is a white circle sticker on it
I think your advice has been spot on and very accurate, this thread raises more questions than it does answers?
You allege this is a known problem and yes it is for older 211's. Can you please tell us the bulletin you are referring to that suggests this fault applies to this specific vehicle?
Question Time![]()
Good morning Lexon,
We are all totally on your side regarding this issue but you have raised a few questions that have been niggling me.
Was this a brand new vehicle?
Did you order it through your local Mercedes-Benz Main Dealer?
What is the paint colour code? It can be found on the B-pillar and will be three numbers possibly preceded by a letter.
When did you order the car and was it built for you OR did the dealer have it in stock?
Did YOU ask for a Service Plus Warranty?
Sorry for all the questions but I'm an inquisitive old devil.
Good luck resolving this issue,
Regards
John
.....The MB cover is for "sudden mechanical failure".....as the leak in the radiator to the oil in the torque convertor is a gradual thing!!! its not covered.....nor is the £156 charge for doing the glycol test......
Hi Lexon,The paint colour is 744 Silver metallic (naturally )
The dealer had the car in stock. They had had the exact spec I wanted but I had the kids built in booster seats thrown in.....
Hi Lexon,
Thank you very much indeed for taking the time to answer my questions. I am no expert on these things but I am always curious. The reason I asked for the build date AND the colour code is to help me get a picture of when your car was built.
Please look on this as more of a question rather than a statement of fact.
Your colour code is wrong for a car built after December 2003? (This should be regarded as more of a query)
ALL E-class 211 vehicles EXCEPT 4Matics built after this date will have a letter 'C' before the number ie C353
Have you checked to make sure there is not this letter?
Suffice it to say I am curious.
The warranty that we all recommend is Service Plus. There is NO doubt in my mind that this issue would be covered. No doubt whatsoever.
If you are right about the colour coding then I would be taking this issue very seriously as something is not right? (question)
It could be that someone with more knowledge than myself will disagree and I will then be better informed but until then I'm happy with the December statement and am aware of a number of E-class that have the nano paintwork with an October 2003 build date, but December is the official date line.
Regards
John
Now as for the warranty......The MB cover is for "sudden mechanical failure"......
My only reason for asking was to see if there is anyway of identifying cars that have the new radiator fitted.Is there any point?
We are perfectly happy with our car and it has none of the problems described by the complainant. I am interested because it is possible our vehicles were built with one month, but that needs to be confirmed by the answering of my nosey questions![]()
Truth be known I haven't got over the week-end GTG yet and I don't relish the thought of going out to the car.
Regards
John
A very fair point but Mercedes-Benz are emphatic this only applies to cars built before 09/2003. I'll print off the document that highlights the brand of radiator and then try to translate it into 'she-male' talk.My only reason for asking was to see if there is anyway of identifying cars that have the new radiator fitted.
Many people ask,"am I OK", as it stands now there is no way that I can advise anyone that they are OK, is it a modifies radiator that has leaked.
Hi Lexon,
If you open the driver's door and look at the base of the 'B' pillar you will see the colour code numbers.![]()
I'm hoping it will have a 'C' in front of the numbers.
Good luck,
John
The service bulletin that highlights this problem does not apply to your car as the code you have kindly supplied indicates your car was indeed built AFTER the specified period? I am NOT doubting what your saying I am simply suggesting your car falls outside the specified time period. It's just as well you did not go into the dealership with all guns blazing, saying how there is a recall out for this known problem. Yes there is a service bulletin, but it is very specific regarding what vehicles it applies to. Well done for handling it how you did, and well done to Mercedes for rectifying the fault.Got the car back and checked the colour code. The code is C744.
