Hope you get it back in fine fettle soon.I dropped the car off at the garage today - in a cloud of smoke Pulled into the car park and saw smoke coming from the passenger side, popped the bonnet and it was coming from that side of the engine. I had seen some oil spots on my garage floor the other night so I guess the leak had gotten worse. The garage (run by a former MB master tech) knew exactly what it was just by my description so with any luck the dealer will stop trying to claim that this is "normal" or "acceptable" now.
I guess I'll be without the car for a little while now though as it sounds like the covers aren't always easy to get hold of.
Yeah looking forward to it! Definitely takes the shine off the new car experience when there are things to get sorted out.
I'll pop you a PM once I have the car back, I do like a W205 and part of me was tempted to go that way instead of a 204 but budget didn't quite allow!
There’s always a niggle or two, even when brand new. Will be a distant memory soon enough.
Cool, I don’t think you’ll be disappointed with the 204, I tried one back when they were current and was blown away by the sound and sheer grunt of that 6.2. Couldn’t find the exact spec I wanted at the time, then got sidetracked into something else. The 205 is nice, but less shouty in its delivery. I wanted a car still under manufacture’s warranty, so that’s the route I had to go.
Get the valve mod if its PFL and has the performance exhaust it shouts then
Try to stay positive. All being well, the dealer has repaired/fixed issue 1 and 2. Made an attempt to fix 3, it hasn't worked so they will go to the next step to resolve the issue. They will be fixing point 4 next week and once answer for 5 is found 6 is an easy and cheap solution.Picked the car up from the garage today:
Sitting here with a large whisky telling myself it'll all be ok The garage said Mercedes don't sell the front wheels any more so that might be a problem. At this rate I can see the car going back...
- The oil leak on the passenger-side cam cover they think was just loose bolts so they have cleaned and secured it all. I could still smell oil burning after the 8-ish mile drive home but could just be left over from before. Will monitor.
- Rumble from rear is suspected badly balanced rear wheels so that's been done. I'll check that tomorrow.
- Sunroof was lubricated but still no better, to be disassembled and rebuilt.
- Front brake judder suspect due to very badly worn discs. New discs and pads to be fitted next week.
- Both front wheels buckled and have bad repairs. Not sure what the plan is there yet.
- Steering wheel misalignment requires wheel alignment, this will be done once wheels sorted.
