Thank you sir!
Regards the other parts, I had the nearside top cam cover replaced under warranty a few months ago, can I safely just replace the gaskets for that as well as the front cover gasket? Also, where are the phaser bolts you mention?
As for doing the job, can it be done from the front of the car or is there much need to get down the sides? My garage is fairly narrow so if it can be done front only then I can do it in the garage and not have to worry about running out of time, daylight or dry weather.
Have a go here:Happy to replace the gaskets as good practice anyway, will get a set of those for each side top and front covers and the phaser bolts and washers.
On a related note, is there any sort of online (or offline) parts catalog you can use to find part numbers for Mercedes models, ideally with diagrams?
I love how members of this forum are so generous with their time and support for others.Just the handy tools, tork bit set to open up, lots of old rags, brake cleaning fluid (a few spray cans).
Small hand mirror and torch to set the timing to 40degree. I found removing the fans and radiator gives a lot more access, so usefull to keep some distilled water and antifreeze handy.
Also need the following parts.
4x new phaser bolts and washers.
Replace the front timing cover gasket (advisable)
Replace the top timing cover (advisable)
Will watch this thread and support you through the process
PS I wish I was handy with the spanner’s like you!
Ah I see, oh well it is what it is I guess. Not sure I have a torque wrench that starts as low as 10NM either...
I was planning on working on one bank at a time rather than removing all four adjusters at the same time, surely no need for two locking kits?
I mean if the camshafts are properly locked on one bank then it shouldn't be possible to turn the engine at all, right? And if only one cam cover is off at a time then it should all be safe enough?
I have two Teng torque wrenches already, the smaller of which starts at 19Nm, happy to add another one to the collection I'll need a 27mm socket for the pulley too.
Camshaft adjuster screws I read were 14.7Nm? And I thought the phaser bolts were only 27Nm?
Edit - this is where I saw the 14.7Nm for the adjusters - M156 M159 Camshaft Adjusters Wear Problem - JMSpeedshop !
