Checking in for a wee update. No recurrence of that rough running/fault codes issue since then but will keep an eye on it. Listening out more for the
camshaft adjuster rattle for any changes, in case it was somehow caused by that. Intending to get the rebuild kit from Canada and hopefully do that over the winter. Shame I'm not closer to Essex as there's someone down that way that specialises in rebuilding the adjusters.
Had to change the right cornering lamp bulb. I've never had a harder time changing a lightbulb in my life. Old one came out easy enough but it took several attempts and cost me a lot of skin off my knuckles. I still got the warning on the dash after the new bulb was in but hoping that just needs a drive cycle to clear because if the new bulb is shot or it's a different issue then I'm not interested
Got another little upgrade in the post last week, fitted today:
Ordered from
eBay, came without the plastic frame which clips into the silver surround so I also ordered an old standard one (so I didn't have to butcher my existing standard shifter and glued the new gaiter to that. I like the look of the AMG badge on the shifter more than the Mercedes logo and the leather feels a little nicer. The knob sits lower on the lever though so gives the feel of a shorter throw. It secures on the lever by a small grub screw you turn with a small Allen wrench through a little hole on the front of the knob so we'll see how well it holds. Around £100 cheaper than the OEM 507 edition shifter though!
