Ted
- Feb 26, 2004
- Location
- Bourton on Dunsmore
- Lexus RC300h F-Sport, Toyota C-HR GR sport
Apart from the jiggle pin allowing a very small amount through, when closed, that's pretty much it, except it really opens enough to keep the engine at optimum.ItalianTuneUp said:So I suppose the thermostat should remain closed when the engine is started from cold until up to operating temperature, and then once this is reached, it opens and closes to keep engine at optimum operating temperature?
When fully open, if the passage of air through the radiator isn't enough then the electric or viscous fan more or less controls the temperature.
Other than a small bleed, the top hose should remain cool until up to temperature and then suddenly feel hot as the stat opens.
