tagnut
Just to add that the SL (R230) amg wheels are same offset (30 front and 33 rear) and fitting as on a W211 so even though the part number will show them as SL they fit fine.
I have exactly the same tyre spec on a set of SL wheels which I bought a couple of weeks ago. No issues with tyre rub at all but the correct sizes for your W211 are 245/40/18 for the front and 265/35/18 for the rear. I would switch to this spec when you get the new boots put on
Brilliant, thanks. I feel a little better now
So, let me get this right - it is fine to put 245 on front & 265 on the rear then..? Just seems a little odd that different sizes are currently on there...
What tyre would you personally go for chap..?
Haven't bought these second hand wheels yet. Will they fit a CLK320
Rim size
Two X 9 1/2 Jx19H2 5 x 112
Two X 8 1/2Jx19H2 5 x 112
ET 31 et 33
Aha this now makes perfect sense thank you!Last column in the fitment guide has notes if modification is needed. Obviously this only applies to standard cars so if your car is for example is lowered then it may not fit without any modification.
Front alloy wheels: 17x7.5" ET37
Wheel part number: MER B66471511
Additional alloy part number: A2034011802
Rear alloy wheels: 17x8.5" ET34
Wheel part number: MER B66471515
Additional alloy part number: A2034012402
Front alloy wheels: 18x8.5" ET35
Wheel part number: BRA 612-858-35-RDK
Rear alloy wheels: 18x9.5" ET35
Wheel part number: BRA 612-958-35-RDK
