milleplod
Yes, no problem with those fitting.
Great - many thanks for the quick reply!
Pete
My brain hurts!!
I am looking for winter wheels/tyres for my 2016 S212 (running standard 18 inch alloys)
Will a set of 7.5j x 16 ET 42 from a W211 fit and be safe to use??
I think the correct offset should be 45.5...will this be a problem? I assume I will need 14mm bolts.
Cheers!
Thanks. The car is an AMG night edition. Not sure the 16's will fit over the brakes! Bit of a minefield getting this sorted
The W211 wheels should fit and the ET will be no problem (W211 ET42, S212 ET46)
The W211 16" wheels will be 7.5" wide and the S212 recommended width is 8"
Both models use M14 bolts.
Would 17" W221 wheels be OK? The ET is 43 so I assume so based on what you have said about...
Wow, thanks for the very quick reply, very much appreciated.^ They should fit easily.
Hi all, I’ve stumbled on this forum but the guide didn’t help me....
Does anyone know what wheels would fit on a Citan?... or should I go to a Renault forum
