For Info I replaced my thermostat (e320 CDi 2000/X model) last week following the recent sub zero weather the engine temp was barely moving off the rest point until the ambient temperature went above +3c. In the summer it would get to around +60c on the gauge. Effectively tracking the abient temperature albeit not proportionally.
Over a period of 3 years the stat has gradually deterioted to the point where it was starting to open around 40c. It wasnt jammed open as the top hose would remain stone cold until the point when the stat opended.
Temp now runs at just over 80c on the gauge and doesnt vary regardless of traffic or motorway driving.
This is how it should be from the factory.
Warm up time to +40 is exactly the same but obviously it now continues up to +85c approx'.
On average morning trips comprising 3 miles urban crawl (reaches +50c) then onto motorway engine gauge reads +85c after approx' 4 miles on motorway.
The stat for my model year is 92c, early years were 87c.
Approx' £28 from dealer (wasnt is stock)
Fiddly to change due to restricted access but not technically difficult.
Allow 1 hour start to finish
No need to drain system (no easy drain points to access anyway.
Siphon with small bore tube in expansion tank
Disconnect the small bore hose that connects from the from stat housing to the expansion tank at the expansion tank end.
The hose is long enough to drape over the front of the engine bay into a bucket in front of the car.
With a cold engine start and allow to idle
The coolant pump will discharge coolant into the bucket until the level drops to the same level as the stat housing
Switch off and remove housing and stat assembly
Replace with new item which includes housing, stat, temp sensor and o ring gasket.
refill.
Job done.
It will still take for ever to heat up if left on idle but thats the same for most oil-burners
Mine is around 80 degrees this time of year just pottering around , goes up to 85 when the weather is warmer or in traffic not that i hold that much store in the gauge has done from new.
Hopefully people will understand that a 92 degree thermostat does not mean a running temperature of 92 degrees
Great thread
