If you're charging at home the mileage will certainly be very cheap compared to an ICE car, but possibly not quite as good as you think. As discussed here at some length
![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
if that £1 for 40 miles is based on consumption data reported by the car then it doesn't include the mains kWh lost while charging, or used to get the car warm and cosy before leaving. Both of which you will also have paid for.
Looking at the independent testing done by ADAC in Germany the ID.3 is actually pretty good ... the charging loss they measured using a wall box was only 12-13% (depending on the model). Worst case was the electric Mini Cooper, where 37.6 kWh was needed to charge the 28.9 kWh (usable capacity) battery ... a loss of 30%. Wall boxes are more efficient than a 'granny' cable run from a 240V domestic socket - losses are even higher with those due to the low charge rate (there's a fixed overhead in powering the 12V systems in the car used while charging, so the longer they run for the more power they consume).
If you pre-heat/precondition before leaving the mains power used for this is very variable, depending on the ambient temperature and size of the particular car/battery. The only specific example I've seen quoted was 2 kWh for a Tesla Model 3 at a few degrees C (duration approx. 40 mins IIRC). ADAC's testing is done at a controlled temperature of 23C and AFAIK they don't look at pre-heating.
