The EV fact thread
I might have dreamt this . Was there not a car (in the 1980's ??) that if the front seat passenger in a right hand drive model stamped on the footwell the brakes came on ?? Something to do with RHD cars being poorly adapated.
I am inclined to say Skoda ? I'm off out soon but it's stuck in my head so I might Google it later.
Or it could be complete Boll0k$
In this respect, there's no difference in essence between EV and ICE - in either case the transmission transfer to Neutral is electronic, not mechanical, and if the computer decides that you can't put the car in Neutral, then you can't put the car in Neutral... end of.
Also, the same applies to turning off the car (EV) or switching off the ignition (ICE) - these days the systems are both electronic, nor mechanical and not even electric- i.e. you are not 'cutting off' electricity to the engine, like with the ignition switches of old. Again, if the computer decides that it's not having it - then you're effed....
So basically if "computer says no" your F***** No matter what your Driving. o_O:oops::rolleyes:
That's possibly quite feasible. :oops:
As the computer is energised via the main Power button one would imagine there would be a 'failsafe' operation? In the owner's handbook for my Lexus it describes how to stop the car should the normal operation fail. Press and hold the Power button for 2sec or more or press it briefly 3 times or more in quick succession i.e in panic mode!! o_O🤣
Which you definitely would be in. 🙂
The probability of the mechanical failure that allows ICE runaway coinciding with a computer glitch preventing the selection of neutral is beyond calculation.
EVs where everything is under electronic control?....
I had an ICE 'runaway' on a car with twin carbs - the linkage connecting them came undone and one carb went fully open (it was spring-loaded to do that - nice design!), which was enough for the car to keep accelerating. I turned the ignition off, end of drama.
All rather academic really seeing as diesel runway is exceptionally rare. Probably because common rail diesels are generally pretty fussy about the type of oil they can burn.
Which is rarer - Car fires, Diesel cars runaway engines, unintended acceleration? Unfortunately I don't have an answer.
I had a diesel runaway many years ago, It was a ommon rail Renault Laguna.
Agreed, and yet there are reports of this happening (long before EVs entre the market). I never quote understood how it is possible, if I'm honest. But seeing that police were involved in some of these cases, I have to accept that it isn't a hoax - see for example (from 2006):
Also:
BTW, the chap in the iPace apparently had this happen to him before in the same car - personally, for me even once is once too many... I would have never driven the same car again...
A few years back, I saw someone crash a Ford Escort at the Costco car park - I heard an engine accelerating very rapidly, coupled with screeching brakes sound and the Escort crashed into a parked car at max engine revs - there was a child in the front seat who wasn't wearing a seat belt and cracked the windscreen with his head, sadly. He seemed to be not too badly hurt though - paramedics took him away while he was fully conscious. The driver (presumably his father) said that the car just accelerated by itself and didn't stop in spite of him stepping on the brake pedal. My guess is a mechanical fault with the accelerator pedal or throttle linkage - if the driver had more time to react, he would have probably been able to take it out of gear or switch off the engine, but it all happened very fast.
He could have and should have killed the engine with the key. On a straight motorway, the steering would have been manageable without PAS.
Presumably the garage/dealership assured him it was fixed.
  • Like
Reactions: Ted
Declutching would have sufficed.
If manual, yes. In any event, the entire episode took under 10 seconds - I don't think the driver had enough time to properly think it through, let alone react.
True. And as long as the key isn't physically removed from the ignition, the steering wheel lock wouldn't engage, either.
Obviously he must have been reassured - my comment was to say that I wouldn't be.
But in that split second, in such a short space, he was only in a Car park, would you even think do that or anything else, for that matter. If you had more time to think then you probably would do something like that.
With a foot over the clutch, thought not required - instinct.
In one tenth of a second the clutch pedal would have been on the floor and the key turned back a second later if it'd been me. That was an avoidable accident - with just a modicum of competence.
  • Like
Reactions: Ted
This was a point raised in the case of Sully who landed on the Hudson, the insurer claimed that pilots were able to successfully land the plane on a simulator:
"Flight simulations showed that the airplane could have returned to LaGuardia, had it turned toward the airport immediately after the bird strike."
But Sully's point was that the pilots flying the simulator were told in advance what the problem was, however if you add the time needed for a pilot to assess the situation and decide on the action to take, then safe landing at LaGuardia was no longer possible.
I once managed a roundabout on a NSL dual carriageway without PAS or much in the way of servo braking after the engine stopped dead on my Ford Granada (it was an auto, so no engine braking to speak of either). Took a bit of effort for sure, but I got away with it.
