Bellow
Hardcore MB Enthusiast
Really, it isn't.No need for dynos....as discussed elsewhere on the forum. EGR is basically for taking care of the emissions at the idle
How can they check it is working?( though it helps at other engine speeds also). so if its working at idle I think they can safely assume it working under load to
Exhaust backpressure exceeds inlet pressure.....not that they do much then as they are usually fully closed under load or you would loose all your boost through them!!
True, but when it costs £2k to put right, I have some sympathy.True....but largely self inflicted....anyone with EGR, DPF AdBlue deletion knows full well that its illegal, voids insurance, lumbers you with a potential £1000 fine etc....so they made that choice. Cant do the time etc......
Unless and until it happens the whole 'clean air' argument is a sham.If it takes more illegal, polluting dervs off the road I'm all for it.....and I have two fully legal dervs on the drive!!
