Ahhh!....But that's an EV enough mistake to makeOnce upon a time…………
In a land, far far away………..
This thread was about EVs!
Bit early for the Christmas crackers to be open?Ahhh!....But that's an EV enough mistake to make![]()
...but I spend all year writing themBit early for the Christmas crackers to be open?
Mine , on the other hand , still sitting on the drive, was built in Bremen Germany , I would imagine back then building 'cooking' RHD drive models in SA made perfect sense for the UK , Australian and South African market.My (now sold) W203 was built in the Mercedes Benz East London factory in South Africa.
I’ve a 2 mile round trip to make shortly, I think I’ll fire up the biggest car on the drive, after all I am picking up a mate so it must be justified.Another day with lots of driving, albeit our FIAT 500e EV was weapon of choice for much of it. Lots of relatively short journeys are perfect for an EV. I hate the thought of starting and stopping a cold ICE engine, and I shudder at doing it several times.
I have to say I find myself jumping into my little B250e surprisingly often for these sorts of trips and it was in use most of yesterday for the same sort of of trips no doubt!Another day with lots of driving, albeit our FIAT 500e EV was weapon of choice for much of it. Lots of relatively short journeys are perfect for an EV. I hate the thought of starting and stopping a cold ICE engine, and I shudder at doing it several times.
Now if only my ICE car had started this morning, I wouldn’t have even had to charge this one away from home. More on that later![]()
Good point! Why isn’t it simple to unplug a diesel engine and just fix broken bits in a home garage?I think there's a bit more to it than that.
Some EVs have batteries that can be removed from under the car, but others (typically conversions of ICE models) have 'built in' packs that can only be accessed from inside. Simply moving/handling packs that weigh half a tonne or more isn't trivial. Particularly when impact damage is a known trigger for thermal runaway ...
Replacing individual cells may not be a great idea. The battery would almost certainly have been constructed using identical cells from the same manufacturer and batch. So if some have started failing then it's likely that others won't be far behind, in which case you could be back to square one pretty soon (which is presumably why the Tesla battery 'repair' companies in the US don't appear to give any warranty on their work). Apart from that any new replacement cells would have different characteristics (internal resistance and usable capacity) to the aged ones in the pack. From what I've seen it's generally whole 'modules' (banks of cells complete with management circuitry) that get replaced rather than single cells, but of course that doesn't address the issue that other original modules may need replacing soon.
With underslung packs sealing (to prevent water ingress) is critical. IIRC some manufacturers have got this wrong on their factory assembled units, so there would definitely be equipment & training challenges for aftermarket repairers.
If it was that easy to return failed/damaged battery packs to fully serviceable condition (along with a warranty) then I'm pretty sure car manufacturers would do this (perhaps via an external specialist) rather than replacing the entire pack with a new one ... which AFAIK is what they all do.
Almost as bad as the typical school run diesel. HopelessMy Leaf is basically a 15 year old design and you press a button on the app and it's lovely and toasty with it's electric heater when you get in it.
We have now discovered that SWMMMBO Hybrid Sportage does not have a electric heater in any shape or form. So you can do a 5 mile round trip without the petrol engine kicking in whatsoever which equates to zero cabin heat![]()
Quality !
depends on the mileage, of course.I’m a bit more open minded.
I currently have 3 petrol cars on the drive, each for different purposes, clearly at least 1 of them could be electric and almost certainly will be in the future. I’m waiting for prices to settle first.
Having said that, one vehicle isn’t quite doing 8MPG on the journeys that I use it’s for so maybe I should worry less about purchase price!
Boxing Day trip out to visit Daughter and SiL. Full charge over night. Pre-conditioned the car 15 minutes before so nice and toasty when we set off, heater/steering wheel heating/bum warmers on full. Drove 70 miles there, mix of M way and A roads, beat up a few middle-age boy racers on the twisty bits and M way. Arrived, had a lovely lunch and catch up. Pre-conditioned the car 15 minutes before setting off to return so nice and toasty as we waved goodbye. Drove 70 miles back, heater/wheel steering heating/bum warmers on full. Beat up a few middle-age boy racers on the twisty bits and M way.
Got home, plugged the car in, went inside and had a lovely evening.
These ev cars are tough to live with, but we are determined to make the effort…..
Sounds a bit like my day… the Model S gave a DB12 a run for its money.Boxing Day trip out to visit Daughter and SiL. Full charge over night. Pre-conditioned the car 15 minutes before so nice and toasty when we set off, heater/steering wheel heating/bum warmers on full. Drove 70 miles there, mix of M way and A roads, beat up a few middle-age boy racers on the twisty bits and M way. Arrived, had a lovely lunch and catch up. Pre-conditioned the car 15 minutes before setting off to return so nice and toasty as we waved goodbye. Drove 70 miles back, heater/wheel steering heating/bum warmers on full. Beat up a few middle-age boy racers on the twisty bits and M way.
