ACheesewedge160
Hi all,
in March I had the front discs and pads replaced on my A160. since then the car has developed an odd click noise when you press the peddle. The click happens a second or so after the peddle is pressed and can be quite loud at low speeds.
Its not the ABS kicking in and the discs and pads have now been check by the garage twice and it never came up at the MOT althought the lack of brake fluid did. the fluid has been changed and topped up due to new hose's but the clicking remains.
Could it be a loose something in the suspension/steering that is clicking under the braking pressure?
HELP!
HELP!
