johnnybravo
Hey guys,
my car is a C200 petrol manual with 136,000 miles on the clock. i acquired the car with 121,000 miles and is my third w202. its not given me many problems at all in nearly a year except this one which i will try to explain in as much detail as i can.
1. serviced in feb 2012, oil, air, fuel and pollen filters replaced, engine oil replaced, liquids topped up but NOT the spark plugs.
2. april 2012, after driving on the motorway at 70mph, slowed down to a traffic queue at a junction and the car shook like a washing machine and the engine choked and had very little power although the car was just about 'drivable', kind of like it was running on a couple of cylinders only. i parked up, switched the engine off, re-started and it was fine. it didn't do this again and seemed fine.
3. may 2012, i had the fault codes read from an indy and have attached these as a jpeg also. it wasn't a STAR diagnostic machine but he wasn't really helpful in regards to explaining what i would need to do to sort my car.
june 2012, after driving in local traffic, the same thing happened. i switched the car off but this time the limited power was still there, couldn't get over 20mph, revs wouldnt go further than 2k with full foot down. engine sounded rough and visibally shook more. this problem stayed every time i re-started and accelerated.
i left it over night and returned the next morning, drove the car round the block (just about whilst looking like an idiot) and the same problem. therefore, i immediately changed all four spark plugs to brand new ones. (ive attached a photo of the old ones). i did notice some oil on top of the coil pack nearest the bulk head and also in the cavity whn you remove the top cover of the engine.
changing the spark plugs made a huge difference, the engine was quieter, revved smoother and the car was driveable again. i even then put some red-ex injector and fuel line cleaner in the tank to make sure. i thought i had cured the problem but there still seems to be a lack of power, a restriction somewhere because the car wont accelerate as fast as it should. also, on the motorway, it wont accelerate further than about 65mph, full foot down, theres no power there
i haven't had any of the above fault codes deleted just yet, but i'm sure there is another parts change to do immediately, i'm thinking:
HT LEADS
COIL PACKS
MAF
everything is still original on the car and i want to keep it that way mechanically but also maybe use OEM parts that are BETTER than the original if there is such a thing. i'm leaning towards buying a bosch replacement MAF unit. do you think ht leads should be first?
i'm wanting to get my w2020 to a pristine example, not too heavily modified but decent. i hope ive explained the problem thoroughly, because my car has performed exceptionally before this, what should be my next port of call? any experts who can encrypt the fault codes and explain which parts i need?
thanks
4.
HT LEADS
COIL PACKS
MAF
thanks
4.
