Unfortunately, while testing the new software I've found that it doesn't like files from Kremmens software. Your best just downloading the Garmin .csv files from PGPSW and then running them straight onto your card using the Garmin POILoader.
You had to do that anyway, Kremmens isn't an 'instead of' it's an 'as well as' and allows you to add things or delete things. But the new software in the Merc doesn't like it :-/
I edit the files myself manually, that seems to work. This is in effect what Kremmens software does, it edits the camera file, and you still then had to use POILoader to get the info into your system.
I use.
Speed zone complete. You don't need any icon files, the Merc won't use them.
I Edit all the files and change each name to 'GATSO AHEAD! FIFTY@0'
'MOBILE AHEAD! THIRTY@0'
'SPECS ZONE! FORTY@0' etc, etc
That's not the name of the file, that's the name of every camera, I just use excel find and replace function.
The @0 is important because otherwise the Garmin system bombards you with warnings.
I then load the file via POILoader but in manual mode. As it loads each file (these are the files now not each camera) it will ask for your alert preference, either speed based or distance from; I select distance from and then accepts Garmins default distance.
This produces the best results, you get almost all cameras. But, it does still simply ignore some, for no fathomable reason I can find. Garmins are known to be funny anyway, but Merc have added extra fun! :-(
You can just load the files as is, but as our system displays the names as the alert on the screen you get all the PGPSW directional info 'SE-W_GATSO_50@50' and I don't like it. It's like that because an actual Garmin system is able to use the direction info and ignore cameras on the opposite side of the road, ours doesn't, Merc removed that function.
I still think it's sad that the sat nav in a premium brand car is bettered functionality wise buy a £9.99 Aldi special buy.......
