Do these wheels/tyres fit?? Read this first! Offset/fitment answers within..
I have a lowered W202 c36, I am interested in getting AMG style 3 (old school) and checking your (Murry Systems) PDF file, I should be able to get a set of wheels off a s class with offset 25, if the wheels are wide enough. I am a little suprised at that. I have seen them available on ebay, but thought I needed 37/30 offsets f/r
If anyone can confirm that s class ET25 wheels have been successfully fitted on a w202 I would be grateful.
Dave
hi, will a set of 20' Kahns go on my R230, not sure about width so what's the maximum it'll take???
cheers
I'm a bit confused by the table and can only conclude that these might just fit my W124CE with a bit of luck but I'd like a definitive answer.
8 1/4 J x 17 H2 ET34, the tyres are 235/45 ZR17
Anyone know the definative answer?
Hi
Merc s320 R-reg, can anyone tell me the offset and pcd of wheels I need to be looking for - it's for my girlfriends Dad who is a techophobe so does not do the Internet :)
thanks
cheers
Kahn offer the following for the R230:
RSC 20x8.5ET31 front
RSC 20x10ET28 rear
RSV 20x9ET22 front
RSV 20x11ET35 rear
RSX 20x9ET22 front
RSX 20x11ET35 rear
They fit the 500E in those dimensions. Other models likley to require some work on the arches
Chris
What is needed to make
8.5 x 18 et 44
9.5 x 18 et 46
AMG monos compatible with R129 please
Some sort of spacer or special bolts ?
TIA
Hi Dave
The whole pack in is stock and would be as follows:
16x RAD4182 M12x1.5x55R14 bolts £32
1x RAD2183 M12x1.5x55R14 Locks (set of 4) £30
2x SCC12.061 13mm adapter £110
DHL delivery £7
Total £179
will this work?
I have a 94 e320 w124 sportline convertible with 205/60R15 tyres
I would like to put on some 8 hole alloys off a 1997 P Reg SL500 with 225/55R16 tyres. Will they fit ok - is the offset ok bearing in mind the lowered suspension on the sportline?
Look forward to your response
Tony
255/45R18 all round or with optional 285/40R18 rear
or if they're a lot cheaper:
245/45R18 all round or with optional 275/40R18 rear
Well I finally got the tyres fitted to the rims today (I've only had them 14 months :o, what a lazy sod) - 245/45/18's on the front and 275/40/18's for the rear...and ordered the bolts from alloywheelsdirect today too.
I'm looking forward to the weekend when I can roll on 18's at last :) :) :)
Q.
17" Alshain Alloys
Hi there - I'm new to thjis and could really do with soem help before I part with some cash to buy some alloy wheels. (I have checked teh chart from the previous posting but can't make head nor tail of it).
Put simply, I have a 2002 (W202 I believe) C22 Cdi Classic. It has the small 15" wheels and I would like to upgrade them.
Can someone tell me if these will fit :
17" Alshain Alloys
2 x Fronts 7.5J 225/45/17
2 x Rears 8.5J 245/40/17
Many, many thanks in advance.:confused:
They will fit straight on - if your old 15" wheels are steel wheels then you'll need new bolts though.
I've been offered a set of 235/55/17 from an S class for my W215 which has 225/55/17 on it.
I've had a look at the list, but I can't find this size combination; there are wider ones, taller ones, slimmer ones... but none are 235. Will they fit?
TIA,
Nick
Hi Nick
They will be fine. Consider replacing them with 225/55R17 when the tyres need replacing. They'll also be cheaper.
Chris
