It's VERY hard to damage the paintwork with a rotary unless you pick a harsh abrasive and course pad or have it at high rpm and sit on the same spot.
You know that, I know that but I guarantee there are thaousands out there that will over do things when trying to remove a 'slight' scratch with their rotary polisher.
This is an extract from a
site I found:
Basic rules for polishing:
Polishing rule 1: Use the least aggressive tool or polishing material necessary to get the job done. Hand polishing is the least aggressive, followed by a dual-action (DA) polisher, followed by a rotary buffer.
Polishing rule 2: Do not mix polishing materials. Do not use the same polishing pad or cloth with multiple abrasive materials.
Polishing rule 3: Work in good lighting conditions, and frequently check your work. You will rue the day you polish through your paint because you couldn't see what you were doing or polished in one area too long.
Polishing with a rotary buffer requires skill and training. We're going to discuss the proper use of this versatile tool later.
For most car appearance enthusiasts, a rotary buffer is not a necessary tool. It is essential for professional detailers and painters, who need to properly machine-compound a car.
Polishing with a dual-action machine is a great way for most car appearance enthusiasts to create a perfect paint finish without a lot of elbow grease. Although a dual-action polisher does not have the power and speed of a rotary buffer, it also does not have the potential liabilities.
Hand polishing is the best way to polish when time and effort is not a concern. All polishing jobs require a final hand polishing step to completely remove wheel marks left by machine polishing.
