television
Hardcore MB Enthusiast
Why is it not good for the engine ?
The internal components are moving in a unnatural way, with no thrust or loading
While it has long been reported as bad for all engines to start them up from cold and leave them idling, my personal experience relates to diesels used in railway traction applications. In those cases it used to cause glazing of the cylinder bores which resulted in increased gas blow by and high crankcase pressure.
The problem was that the lower cylinder pressures in a cold engine at idle didn't force the piston rings against the bore so they tended to polish the surface.
I don't know if this is directly transerable to car engines but in the forty five years I've been driving car manufacturers have consistently advised against idling a cold engine.
It's not that long ago, that we used to light a fire under the sump, (and sometimes the tank) on cold mornings, just to get the the diesels to start ! before all these new additives were added to the Derv.
The "older" forum members may know what I am talking about here ?
Surely excess fuelling on the old style pumps can't do the lube oil much good ?
Diesels are less worried about cold conditions in any case, and will produce pretty close to maximum power from cold. I had a perkie 4203 and if you tried to warm it up by letting it idle from cold you will come back an hour later with the stat still shut . Neither letting a cold engine idle or cane it from cold can be good , a nice warm up gently increasing load sounds pretty sensible.
I used to have a Golf Mk 1 diesel in 1985, in the days when diesels were rare and the fuel in the UK had few anti-waxing additives. It was a right pig to drive fast in cold weather, because the fuel would wax up. I would have to stop and let the engine heat soak out, warm up the fuel lines, and set off again for a few more miles ... And do the same all over again.
Coming back to the radiator blinds, my 2CV was supplied from the factory with a muffler for the front grille. The instructions are to use it when the temp is below 8 C. Of course, this is an air-cooled engine, with none of the problems of water, thermostats, etc. to worry about. Oh for the simple things in life!![]()
From memory that was used as a primer for starting aero engines. When we hired a boat on the Avon many years ago we were given a can of quick-start and told to use it every time we started the engine. I guess it didn't have glow plugs?when I got older I used something I believe was called Ki-gas or similar.
I used to have a Golf Mk 1 diesel in 1985, in the days when diesels were rare ........... Oh for the simple things in life!![]()
Hi Bill,From memory that was used as a primer for starting aero engines. When we hired a boat on the Avon many years ago we were given a can of quick-start and told to use it every time we started the engine. I guess it didn't have glow plugs?
For those that watched the recent documtary series on truckers working up close to the Artic Circle we witnessed first hand the use of radiator blinds. These lorries were operating in temperatures sometimes dropping as low as -32f, I dread to think of the wind chill and also night temperatures, but we witnessed the alarms going off when a truck with these blinds OVERHEATED! That to me spoke volumes and yes there might be a place for tampedring with a modern radiator, but go into this with your eyes wide open. Diesel engines will take longer to get to their operating temperature and that is something owners must accept. If they are genuinely concerned then the thermostat as already stated, should be the second port of call![]()
1st port bering to check your coolant levels.
Jihn
Thanks for clarifying this. I am only repeating the figures mentioned on the documentary, but visually this did not match what my eyes were seeing. I would suggest the reality was much, much nearer your figures.I spent a year working in Labrador, Northern Canada.
Temps went down to -40 (c) in winter and as low as -93 with the wind chill factor , whilst we didnt use blinds on the radiators but we did need to plug the cars in if you parked , this used to power a small heater around the battery, in the sump and in the interior.
